Here's your problem. When you put more distance between the frame and the axle, it changes the angle of the track bar. That's what's pulling your axle to the side. You need to either A) get a longer or adjustable track bar (goes from one side of the axle to the oposite side of the vehicle on the frame), or B) look on the passenger side of your front axle and drill a new hole 1" closer to the center of the axle to move the axle back where it's supposed to be (more towards the passenger side. Also, on a straight axle or full floating axle, doing a suspension lift shouldn't change the camber of your wheels. You will, however, need to realign the steering wheel. If it's an IFS vehicle, a lift will change the camber.
