jfrabat
I bought my YJ some months ago, and the idea is to use it as a daily driver for a couple of years while building it in the process so that when I go back to Panama in 3 or 4 (or 5!) years, its all ready to hit the trails.
Now, my YJ is a 4 banger, but I do plan to pu 33" tires on it after I do the spring over axle conversion (it currently has 31", but no lift, and there's basically no room for the suspension to compress without the tire rubbing on something or other). In any case, I am doing all I can to get the most out of the 2.5L. So far, I removed the restrictors from the filter box (stock) and put in a K&N filter. I also put a 62mm Helix spacer, and I bought a 4.0L throttle body which (hopefully!) will arrive before I head home for Xmas, so that I can bore it out to 62mm as well... But I do plan to change the stock airbox at some point. Now, given the fact that i do plan to hit some trails, would you guys recommend an airaid type intake, or a snorkel? I imagine that the airaid type will give me more power, but I worry a little about it when crossing rivers and stuff (ussually not so deep, but I still would be focussed on that). Do you think a snorkel would benefit performance (I imagine it affects air temp taking the air from higher up and out of the engine compartment), but dont know just how much...
Any experience with this? Comments? Suggestions?
