1058333
What I did was took one pack from a chevy 1/2 ton... i've had the pack sitting at a garage for about 8 months... now seeing that he is not going to "have time" to let me use the lift... I decided to grab it and do it elsewhere... I am using the two longest ones, which are each longer than my main... and I am cutting them to equal length to somewhere a between my main and the next leaf.  then the two shorter of the pack will be cut to equal length and placed in my front pack.  I will be dropping my axle from my springs, dropping all helpers, then installing the new leafs where they best fit, replacing the center pin, then making new retainers.  I am mainly doing this to help with my sag.  I want to take some pressure of the air shocks in the back.  It seems as thought this will work quite well.  [addsig]
