AC Compressor won't engage
Cgorman21
I recently replaced my seized up AC Compressor, drier, and orifice in my 98 Sahara. Pulled a vacuum, verified no leaks, and put as much r134 in as possible without the compressor engaging. I used a 14 gauge wire to jump the low pressure and high pressure sides with no luck. When I jumped it directly from the compressor to the positive battery terminal it engaged immediately. I swapped AC relay with one I know to be working. Any suggestions what could be my issue. The slider works for fan, heat, etc. but I cannot get the compressor to kick on. Thanks.
Is there a sensor by the drier? That's the one I jumper to engage mine if the pressure is to low to kick it on
Check both fuse. One in the fuse block under the hood and one behind the glovebox. If one of those fuses is blown, the cycling switch won't engage the clutch.
