Hi, on my '93 GC Laredo, for a long time i had a short across a fuse in the fuse box, and my abs for a very long time has been throwing up an error light. finally tracked down and fixed the short, but now my abs is acting up, but not throwing any codes. if i am moving about 15 mph or less breaking, the abs will freak out, slam on the breaks really hard, and then refuse to let up until i turned the jeep on and off a few times pumping the brake pedal. recently, i took it on the trail, and found that just travelling at speeds under 15mph will cause the ABS to freak out and slam on the brakes, even when i'm not touching the break. i couldn't find anything on this problem, what do you guys think?
any help is very appreciated.
thanks,
alex
thanks,
alex
