A/C control 92 XJ (HELP)
ryedogg
A/C Fan switch color codes as old one melted in to a ball 5 post only 4 used (green,yellow/black, blue,tan)
:shock: :shock:: :evil: :cry: [/code]
What is it that you need exactly? The color of all the wires on the back of the A/C switch? I have an 88 xj w/A/C I can look and post it for you they may not be the same. Probably won't be but will do it if it will help ya out.
I see this is your first post. Welcome!
Hi,
The 1988 Schematics indicate the following:
12 LT Blue = Switch terminal C = Power input to speed switch (from climate control switch) & also low speed (to resistor block Terminal #3).
12 LT Green = Switch terminal A = Medium 1 Speed output (to resistor block Terminal #2)
12 Tan = Switch terminal D = Medium 2 Speed output (to resistor block Terminal #1)
12 White/Black = Switch terminal B = High speed output (straight to blower motor)
Also, yours likely melted due to bad/corroded connections. Any replacement (new) connectors should be soldered on (Not just crimped) to be sure you get good connection for this high amperage circuit. :mrgreen:
-Nick :!:
