a/c clutch relay
donnie850
where is it? how do i test it? i know the compressor and clutch are both good, i hard wired it. So now what
FYI, the A/C sytem is equipped with a pressure transducer switch, IF the freon level is below the threshhold, the a/c compressor relay will NOT enable thus not engage the a/c compressor clutch. This switch should be on the a/c line towards the drier canister.
ahhh ok... didnt know that. Well its defiantly low on freon so ill give that a shot first. Thanks for the info ;)
