97 4 cyl hesitaion
verobeachjeeper
Hi, all. I am a little perturbed. I am having a little hesitation starting off in all gears. I have done the usual(replaced plugs, wires, rotor, cap, air filter) and still cannot figure out what is going on. When in neutral or the clutch pressed in no hesitation. Anyone have a clue or have this happen to them. Its getting a little old.
1047981
hows' your tire pressure? in the colder months, air molecules condense, and you need to inflate your tires to get them back up to proper pressure. in warmer months you should let air out...
-or- perhaps it is a clogged fuel filter...
-or- a brake is rubbing
-or- clogged cat (not you dumbass *looking at my cat sitting on my computer screen, purring*)
-or you just got a REALLY BAD tank of gas... just fill it up next time with a higher grade and see what happens...[addsig]
1047982
All of those are perfect, I have been through about 20 tanks of gas since the problem started, and i live in South Florida so I guess we really dont have weater changes.[addsig]
1047990
...know what you mean...I'm over here in Lakeland...two seasons...50wks of summer...2wks of "winter"
1048418
Well if your jeep is a stock jeep all of thoes above should work. But if your jeep is lifted and has bigger then stock tires it would be your gears. With stocks gears and bigger tires you'll be under geared.[addsig]
