96 Grand Cherokee Lerado
sneakers
I have had this Jeep since new. Now has 154500 mi. Recently the vehicle info center display went blank. I have checked fuses and all are ok. I can find no indication that there are any relays in line. Although it has been 15+ years, I seem to remember this same thing happening when it was still under warrantee. They only had it in the shop for about 1/2hr and said it was just a fuse. I would hate to try to find a nos part or a used one when it is a simple fix. Any help would be appreciated.
Thanks: Ernie:???:
Well if you checked all the fuses. Check the connector behind the panel. On many models they wiggle loose
Especially grand cherokees. But the victim is super cheap to get a used replacement at the junkyard to test out
