94 Trans Oil?
75w-90 should work fine.
*Transmission (standard):
- 80 weight gear oil but most recoment Redline MT 90 to protect the interals better. 75W90 is listed by some shops but 80W should be fine.
AX-5 = 3.3 quarts
AX-15 = 3.25 quarts
BA-10/5 = 2.45 quarts
*Transmission (automatic):
- Automatic Transmission Fluid (ATF) Dexron III
TF 904 = 4 quarts
TF 999 = 4 quarts
Most gear oils on the market are GL5 and are harmful to your AX15 transmission. The high sulfer content of GL5 is corrosive to the soft brass syncronizers. I recommend Redline MT90, it's a synthetic that's specially formulated to be easy on the syncros and for easy shifts, even when cold. I order mine from Summit, pricey but well worth it to save a transmission rebuild. Redline can often improve notchy shifting as well.
If you don't buck up for Redline, at least use Syncromesh, it's available locally.
It's a gear oil available at most all parts stores, Penzoil Synchromesh is a common one. Easy on the synchros.
