86 Comanche, F250 Dana60
stiggity
Greetings All:
I have an '86 Comanche 4x4, 2.8, 5Spd
I recently purchased a Dana60 Rear, out of a F250.
Has anyone installed another rear in there Xj, or anyone
know of any links to where i can get some more info.
I know the housing is alot bigger, and im going to lose some
ground clearance. Anyone with some experience in this
area would be more than helpful. What would the pro's
and con's be of installing this rear. Any help would be
greatly appreciated.
Thanks,
-Stiggity
stiggity"@"suscom.net
1042639
Too wide,wrong gears(maybe),different bolt pattern for wheels,driveshaft will need to be modified,new spring perches welded on.......
1042693
Yeah:
I am pretty sure the Dana60 will not bolt right in.
As far as fabricating the rear-end too fit into my
"truck", i have a MIG Welder, O/A Torche, and
the rest of the "goodies" to install the rear. I
guess my question should have been more along
the lines of, Have any of the Guru's, or more
experienced people, attacked a project of this
difficulty level? And if so, what problems were
encountered, any "hints", "tips", URL's to actual
dox on the install.
Also,
What advantages would i gain on an this install?
An obvious strength advantage, but is it worth it
losing all that ground-clearance with the much
larger "Pumpkin". Driveshaft/Spring-Perch(sp),
steering linkage, etc.. shouldnt be All-That Diffi-
cult. Again, any help will be greatly appreciated.
-Regards,
Stiggity
stiggity@AT@suscom.net
