1054273
I'm in the process of lifting my 85 XJ with a 3 inch lift. Just got my 31X10.5-15 BFG Radial All-Terrain tires mounted on it today the stock honey comb 15X7 wheels. Ok, I'm looking at some serious non-clearance between the tires and the fender flares right now after getting them bolted on...as expected.
I purchased a front track bar lowering bracket on eBay...a couple of hours ago.
After doing some serious looking around here and other places online...I think I'm doing this right...
I'm going in the right direction (only sounding confident by checking out this site and MANY others like it) by coming to the conclusion that I'm going to spring for the $230 + or - Rough Country 3 inch lift kit that includes the front coil springs, shocks and rear AAL with blocks, shocks.
Ok, what I would like to know is...should I buy some of the lowering control arms that I see advertised at eBay and other places for about $100 also? Add some longer YJ or
other longer brake lines for the front and rear? Both...one or the other??????
Any thing else I might not be taking into consideration???? I'll be blunt...I'm ignorant about small details when it comes to doing this right. I'm going to throw on a homemade disconnect system for the front sway bar that I saw...what should I do with the rear sway bar...any surprises there? I'm planning on throwing a class III hitch on this thing too...am I going to have issues with that???
I'm probably going to be doing 75% street driving with the occasional urge to go off road...and towing a 3200 lb boat. While I'm at it...should I add the rear helper springs that JC Whitney has...if I add them will it throw off the lift at all or leave it intact?
Yea, I know 50 frigging questions...got you scratching your heads yet or is this something someone else has thought about too?
Ah...the joys of mods! ?
Thanks in advance...
edited by: vfrf2, Feb 09, 2003 - 08:56 AM[addsig]
