78 DJ5F need help
dcg1972
Hey guys, i need to find alternate VIN sites . The plate that was on the firewall is missing, and i have to find a # to title it. Just my luck get a fixer upper and might not be able to register it after building it up.:-|
Sorry, don't know much bout DJ's, but try the top of the frame, next to or near the Passenger rear wheel. You may need to check under the tub somehow.
The only spot I know of is the top of the frame above the right rear wheel...stamped in the frame should be the first 2 characters & then the serial #(last 5 or 6 characters). You may be able to fill in the other #s by description.
eg: 1st 2 characters J8=Jeep 1978
3rd character(transmission) a=auto,F=3ps,M=4spd
4th & 5th character(wheelbase) CJ5/DJ5=83
6th character(GVWR) A=3750
7th character(engine) A=258,E=232
followed by 6 digit serial #
Hope that helps.
have a set of #s from a junker dont know where title is if you want the plate let me know than register as a rebuild
