1071166
>b>IF[/b] the 4.2 intake will fit a 4.0 head, which it should, at least with minor mods... then you have got yourself a good block which can be bored and stroked... the 4.2 crank will have to be machined at the front to use the 4.0 harmonic balancer... i'm not quite sure if you can use the 4.2 balancer... after you get that machined, you will need to get the entire rotating assembly (crank, balancer, flywheel) balanced to each other or vibrations can cause some nasty outcomes... you will be using the 4.2 connecting rods, and will retain the 4.0 pistons... that alone will give you a 4.5... if you overbore, you can achieve 4.6 with .030, or nearly 4.7 with .060... your TDC quench height will be slightly lower than the deck of the block, but that will be fine.. or you can get the block milled to compensate for that, but your compression ratio will increase, and may get in the cautious range for pump gas... the stroker alone will bring your compression ratio up, but should be safe with 87 octane with minor ping if any... i would suggest using 89+ for any stroked 4.0... you may want to replace the camshaft to make up for the increased displacement, crane cams sells one perfect for this application... and since you are staying with a carb intake, you don't have injectors to worry about... if you have any more questions... keep them coming[addsig]
