2012 jeep wrangler
vlad0691
I installed hi lift on the hood,but I have a problem cleaning the front glass.Hi lift covered the water jet.can someone give advice what to do? Thank you
Mount your hilift inside if you want it to work when you need it. The elements are hard on a hilift jack.
I don't understand why anybody mounts them on the hood.
Because it looks cool. No, really. I think it looks good mounted there but the elements are torture to a high lift. Like Bounty said, if you want it to work then move it inside. You can easily mount it to the rear roll bars just above the rear tailgate with off the shelf hardware.
I don't know how you could reroute the washers if you're wanting to leave it on the hood. I guess you'll have to look at either moving the hilift mounts forward or the washers towards the windshield. Either way involves drilling new holes in your hood.
