Add a stock YJ leaf to each spring pack and you'll gain 1.5" without stiffening the ride. Then add a 1" body lift and maybe some TJ fender flares and you'll be able to clear 32" tires.
Like mentioned, avoid excessive length when adding longer shackles, you lose caster and the shackles will hit everything due to the decreased approach and departure angles.
