ok-I installed the 2" coil spring spacers last Sunday-I did not do alignment,planned on doing that today.My Jeep was perfectly fine before,no issues.Long story short,I encountered extreme death wobble.There is so much controversy over the cause of this!I removed the lift after the second time in two days of this!I understand that the only adjustment you can perform on a TJ is toe in,and you have to install adjustable cam bolts in order to adjust caster.I also understand that the track bar is part of the problem.My question is-what do I have to do in order to make this work properly?Since I have removed the spacers,the death wobble is gone,but now I still have a strange vibration around 65-70 m.p.h.!What do I do to get it right?
