drewman said:I went to take a picture but my camera batteries are dead. as soon as I can find the cord to my battery charger I will charge the batteries and take a picture then post it. In the mean time just look at the front of the filter housing. there is a hole where the air enters the housing. this is where the restriction is. it is similiar to the other one and comes out the same.
BaconYJ said:If you change the 2.5 TBI to the 4.0 TBI do you need to change the fuel pump as well to keep up with the extra demand of fuel?
i just got my first jeep, 87 comanche 2.5. having said that ive been a mechanic and fabricator since, well as far as i can remember.
isnt the 2.5 a general motors motor?
i was under the impression that the 2.5 is what they called the iron duke motor. it this is the case there is a lot of stuff available for this engine! cams, pistons, roller rockers even performance heads.
can some one tell me if i'm right or wrong?
thanks
jeff
I could pull 65 on the highway on 35's no problem with a 4 spd, thats pretty much the same as regearing. now on 38's the 4 banger is lacking a little bit even with 5.13's. I can get her to 50, but to tell you the truth, im scared to go over that with it now :lol:
have any of you tried those performance chips that trick your pcm to think the air temp is colder than it really is? i imagine it would just ruin your gas mileage dumping that extra fuel, but w/ a 4.0L throttle body, ram air intake, and maybe a header i'm thinking i could get an extra 15-25hp. if anyone has a wild hair and extra $600-$700 to try it let me know how it goes.
While I'll agree that no single mod will have a huge impact for a 2.5L, doing several can. The most bang for the buck is a electric fan conversion. Instead of trying to squeeze more power from the motor, it frees up some that were already there but being usedcheck out this month's JP magazine, big write up on modifying the 2.5/4.0, basically leave the 2.5 alone, with exception of avenger s/chargers. Bolt on parts do nothing for the 2.5l, sometimes they actually reduce power. If jeep could've gotten more ponies from it, they would of.The throttle body is sized to provide hp's AND torque. If jeep could've just made one t-body for both, they would of, it would've been cheaper. Adding three ponies is not worth your time nor is it noticeable, assuming you actually get them.And you may even lose some low-end. Your 2.5l wiil serve you well, leave it alone and regear your axe's.
While I'll agree that no single mod will have a huge impact for a 2.5L, doing several can. The most bang for the buck is a electric fan conversion. Instead of trying to squeeze more power from the motor, it frees up some that were already there but being used![]()
I'd go with Khaki. Khaki goes with just about anything.:agree:
Now, if JP Magazine had an opinion on which Cotton Dockers went with my Air Nike's and Old Navy Fleece pullover, I might pay attention to them.![]()
