1973 J - 2000 4x4, Front brake conversion question.
Northman111
:???: Is it possible to convert the front drums over to disc & if so, how much work involved in doing so.
Pretty easy if you have a disc brake donor axle to swap the parts over, or better yet swap the entire axle.
Once you do the swap, be sure to swap in a disc/drum master cylinder and proportioning valve in place of your stock drum/drum pieces.
