Thanks in advance for the suggestions while I get up to speed on jeeping.
I am planning a 3 1/2 lift in the spring but need new tires now. I won't be off roading until the spring but want to get the largest tires I can fit on my stock rims as i wont be changing those yet. Hey, I'm shelling out a fortune just in payments each month! I need actual tire sizes that would work for my rims. If I need a spacer for the rims that is reasonable but I really need specifics. I can't translate, you can run 33's on those rims Into an actual tire size that is available. So help me out with some specifics would ya? Prefer the BFG KO2 if possible.
Current tire size is 255/75-17.
Thanks for the help! Jeff
