Baseline 4x4
07-11 Jeep JK Wrangler A-Pillar & Lower Switch Pods & 97-06 TJ AC Switch Pod Kits
Looking for a handy place to mount your accessory switches that doesn't require cutting or other modifications? The Rugged Ridge A-Pillar Switch Pod has premolded cutouts to allow you to mount up to four aftermarket switches in easy reach on the drivers side A-pillar, and out of the way of the shifter handle. Rugged Ridges pillar pod has the texture molded finish just like the factory plastic pillar cover it replaces. It snaps into place just like the OE!
17235.56 - Rugged Ridge A-Pilar Switch Mount Pod Kit, 07-11 Jeep JK Wrangler
17235.86 - Rugged Ridge A-Pilar 4 Switch Mount Pod Kit with Switches, 07-11 Jeep JK Wrangler
17235.55 - Rugged Ridge Lower Console 4 Switch Pod Panel Kit, 07-11 Jeep JK Wrangler with Automatic Transmission
17235.85 - Rugged Ridge Lower Console 4 Switch Pod Panel Kit with Switches, 07-11 Jeep JK Wrangler with Automatic Transmission
17235.50 - Rugged Ridge AC Vent Switch Pod Kit, Mounts 2 Switches, 97-06 Jeep TJ Wrangler
17235.80 - Rugged Ridge AC Vent Switch Pod Kit, Mounts 2 Switches, Includes Switches 97-06 Jeep TJ Wrangler
17235.20 - Rugged Ridge Rocker Switch Housing Kit, 2, 3 or 4 Switches
Rugged Ridge's marine grade switches are design for use with Rugged Ridge A-Pillar Pod and Switch Panels, but are sized to work in most OE dash switch blanks. Our switches feature an OE fit, quality and function. They are available in Red, Blue, Green and Amber. The three post 20-amp design is engineered for use with most aftermarket accessories.
• Rocker Style Switch.
• Heavy Duty Marine Grade surpasses OE Specifications.
• Available in four great colors: Red, Blue, Green and Amber.
• Switch illuminated in the “ON†Position.
• Three post terminal, 20-amp design works with most aftermarket accessories.
17235.01 - Rugged Ridge Rocker Panel Switch, Amber
17235.02 - Rugged Ridge Rocker Panel Switch, Red
17235.03 - Rugged Ridge Rocker Panel Switch, Blue
17235.04 - Rugged Ridge Rocker Panel Switch, Green
