jlpongrass
:???: Have an 03 Jeep liberty, air conditioning works great in the mornings and for about 15 minutes after work, then compressor cuts off , seemingly when the car warms up in the afternoon heat, if shut off for awhile, it will come back on and work for a few minutes then cut off again, then work great the next morning, until the weather heats up, Ive checked the freon, and both high and low readings are dead on when its working, ive seen two sensors on the AC, Ive replaced the sensor on the dryer, and was told at the parts store that this is the high pressure/clutch cycling switch, which sounded like my problem, I dont know what the other sensor does, but it was $80.00 and they would have to order it, if thats it I will replace but i'm not sure, so hate to throw away 80 bucks on guessing, The jeep is a V6 standard. Any ideas will be greatly appreciated, as im sure you have guessed, the cycling switch didnt fix the problem, Thanks!
