Engir
Active member
I have reason to believe that my engine is not the original that it may be from a 93-98 Grand Cherokee and took this image of the block number on a flat area between the distributor and A/C compressor the number is 74OM29 does anyone know of a decoder for this?
I found a thread that said the casting number is on the drivers side behind the power Steering pump this is what I found there.
