Well,I
finally pulled the radiator out (good thing I did, one of the mounting flanges was loose) and after removing the stock fan shroud with the small 18" Flex a lite fan I set the Merc Mystique assembly inbetween the tanks and all I had to trim was the top mounting tab.
[TABLE="class: ncode_imageresizer_warning"]
[TR]
[TD="class: td1"]
[/TD]
[TD="class: td2"]This image has been resized. Click this bar to view the full image.
[/TD]
[/TR]
[/TABLE]
The fitment was very tight but after hitting the edges with my trusty Milwaukee Heat Gun the stress on the tanks was relieved. I was glad to see that the Merc shroud completely covers the radiator core as I've noticed on some posts there's a 3" gap at the bottom.
Then drilled some pilot holes through the shroud and the radiator flanges;
Then ran 1/4" stainless bolts, washers and poly lock nuts;
It really went together so easily and well, I no longer have any doubt that this is a viable alternative to more expensive setups.
Next going to set the works into the engine compartment and check clearances.
Edit: Test fit went fine, except my overflow bottle spilled coolant on the floor while I was under it, momentary panic until I detirmined what was the cause. Much more room in front of the water pump pulley than the previous fan assy. Only mod for mounting up is I made a longer stud for the radiator mount in the nacelle in the bottom left, this'll allow me to mount the radiator
and the shroud with the same stud, given it's location, there was no other way to go.
Edit: Done! mounting the radiator/shroud over the longer stud would've went easier, if I hadn't lost my stubby 1/2 inch combination wrench, my Crescent 1/2 inch gear wrench,
and my damn deep well 1/2 inch socket! All I had left was a shallow 12 point socket, a long 1/2 inch combination wrench and my pudgy fingers. Finally got it on, but you can bet I'm going tool shopping this weekend!
One dramatic difference I've noticed already with the Mystique/Contour fan shroud compared to the setup that was on my Jeep, using the stock AMC fan shroud with the P.O.'s 17" Hayden electric fan is the fan tips didn't reach the opening of the shroud, rendering it inefficient.
