2008 sema jeep jk wrangler unlimited‏ for sale!! $$
This jeep started life as a fully loaded 4 dr jeep rubicon unlimited. Then it received a no expense spared build for the SEMA show in 2010. The attention to detail is comparable to the best of show cars but yet build for extreme off road with the best heavy duty parts available. This jeep is a show stopper whether be at the local cruise night or a 9 rated trail in Moab or take an expedition trip with 4 adults with gear in comfort. It has done it all with poise. It has been used very sparingly, been maintained meticulously and always kept indoors. Here are some of the highlights to this spectacular vehicle:
-Burnsville offroad professionally installed new Crate HEMI 5.7 V8 with 6.1 cam.
-new crate NV7500 6 speed transmission
-MBRP custom mandrel bend T304 3 inch exhaust from manifold back with high flow stainless catalytic converters.
Polished to show finish with a 5" stainless tip exiting on the left side for maximum ground clearance.
- factory options includes: tow pkg, cruise control, pw, pl, AC, tilt, hill asst, abs, traction control, Navigation, Sirius sat radio.
-Currie alum anti-rock on rear.
-JE Reel custom built front & rear drive shafts.
-Currie rock jock Dana 60 axle with 5:13 gears
-Rock Krawler 5.5 inch long arm coil over triangulated suspension lift.
-Racetech sway away 2.5 coil over with remote reservoir.
- dual steering stabilizer.
-Mickey Thompson classic lock 17x9 wheels.
-Goodyear MTR w/Kelvar 40x13.50R17 tires
-Bushwacker flat fenders
-TMD heat reduction ram air hood
-Lightforce lights, 7x170 strikers, 2x140.
-factory fog lights in bumper which makes 11 off road lights all together.
-Daniel Stern headlight conversion.
-Rockhard front & rear roll cage painted body color.
-gen right alum spare tire carrier.
-gen right alum rear off road bumper with LED reverse light.
-Off camber fabrication roof rack, roof rack extension, Cargo basket, hi lift mount, fire extinguisher mount, windshield light bar, stubby front bumper with grille guard & light bar, rocker guard w/entry step, d-ring mounts with power coated d-rings.
-Katzkin leather heated seats, custom stitched in red with black and white matching colors.
-Daystar hood latch and dash pad.
-ARB onboard air system
-Spod module controls all lights and accessories.
-Ramsey 9500lb winch with synthetic rope.
-Xtreme customs body & paint, complete tear down for body and paint, the theme does not end on the exterior, it wraps to the door jam and interior of the doors, wet sands to smooth then covered with 5 coats of clear. Wet sanding again, then polished to a deep wet look. Over 400 hrs on body & paint.
-Ron Gibb airbrush pinstripe. Extremely detailed, must see to believe.
-and much, much more.
This turn key jeep is ready for anything you can throw at it.
It has hold it's own at the SEMA show, stand out among the best of the best custom built Jeeps.
Been trail tested at Moab, performed flawlessly on some of the most difficult trails.
It has been stored indoor it's entire life, been in numerous magazines.
Only synthetic oil been used in the entire drivetrain.
It is one of the most custom and capable JK on earth.
It is in mint condition with no damage.
Never been in accident or wreck.
Owner is a very meticulous car collector.
Must see to believe, no disappointment.
Asking $95,000. Open to offers located in Vancouver BC.
Can be seen at Fountain tire
