2006 Jeep Unlimited LJ Frame - $4650 (Sparks)
offpistejeep
The frame is a brand new "Throttle Down Kustoms" frame. This structurally sound frame is black powder coated and is a stronger rebuild than a OEM frame. It is hard to come by, but essential for a frame swap or rebuild of the "Unicorn" 2006 Jeep Unlimited LJ.
TDK Frame Manufacturing Process
- CNC mandrel bent for better than OEM precision.
- Brackets are CNC laser cut out of 3/16" and 1/4" P&O steel plate.
- Frames and brackets are hand welded in Montana.
STEEL
- Made from 2" X 4" rectangular 3/16" wall A500 tubing.
- Brackets are made with 3/16" and 1/4" P&O steel.
INCLUDED MOUNTING POINTS
- Steering box
- Front and rear upper and lower control arm mounts
- Skid plate included with frame
- Sway bar, front and rear
- Body mounts, grill mount
- Front bumper
- Rear crossmember standard
- Gas tank
- Front and rear bump stop holes
- Motor mount welded in (6cy)
- Steering shaft idler mounting location
- Rear coil spring mount
- Rear shock mounts with 5/16" nuts welded in
- Rear track bar mount set up for stock rear track bar
- Front coil spring mount with shock mounts welded to frame
- Front Track bar mount
Throttle Down Kustoms Mandrel-Bent Steel Frame for 97-06 Jeep Wrangler TJ for 04-06 Jeep Wrangler TJ Unlimited | Quadratec
