Hi guys,
My 1997 XJ has given me the Oil Pressure Warning Light (it only has dummy lights - no actual gauges) for the first time ever in the 11 years I've owned it.
The weird thing is... it only came on immediately after I did an oil change. I did everything just like normal, but right after I started it up with the new oil to check the pressure, the light came on and hasn't gone off since.
Could I just have a bad sending unit/sensor? Or is there a chance the pump is actually out or something? Where should I start looking?
It runs/sounds perfectly fine, and I actually had done the oil change right after a cross-country drive (California to West Virginia).
Thanks in advance for any advice!
