A day before you do it, spray wd40 (pbblaster in your place?) on those bolts, it should help.
If I remember correctly, the size of those bolts is 1/2".
axle nut = 36mm
remove the axle nut before removing the brakes, so someone would be able to help you by holding the brakes down while you try to open that nut.
Saar.
