DangerManV
Hey guys, I am trying to sort out the vacuum lines in my 88 YJ. The original owner stuck a Weber in there and just capped everything off, but it idles messy.
Notes:
I have a five port CTO. Right now, it is all capped/looped.
The EGR canister is hooked into the EGR port on the Weber carb, which seems wrong, to me.
Advance port on the carb is going to the advance canister on the distro.
The evap canister has everything capped except the carb vent and fuel tank vent.
Where should the EGR canister go? I think it should go to the CTO and the EGR port on the Weber should be capped. Even if I do that, what about the rest of the ports on the CTO valve? I don't think it makes sense to just hook up the EGR to the CTO and keep everything else capped off.
Diagrams would help!!
Notes:
