Just a question or two. '99 Cherokee Sport with 135K, and I've had it since it was new. Never a problem, I maintain it well, I tow a small tralier and drive it every day. Just this past weekend I started to pick up a vibration in the drive train. It's not in the front end (the wheel doesn't shake) and it starts at about 55 mph and is the worst between 55 and about 65. After that it's not quite as noticeable, but it does sometimes vibrate a little harder at faster speeds, then slows down. It's a little sporadic, but it's there all the time once you hit about 55. I jacked up the front end and tried to wobble each wheel, but here's no play either top to bottom or front to back, and they spin by hand pretty good. My question (s) is about play in the drive shafts. In the rear, with the Jeep in park and on flat ground, there is absolutely no movement when I try to rotate the drive shaft by hand. It's rock solid and the U joints have no movement at all. The front drive shaft though does have rotational play in it. I can move it about 10 degrees in each direction. The movement doesn't seem to be in the U joints, but in the housings, and it almost seems like it's supposed to be there. Does this sound like the problem, or is this considered normal? By the way, about 3 or 4 months ago I thought that I was noticing a small vibration, but after I rotated the tires (coincidence?) it seemed to go away. I've done a lot of driving at about 80 mph since then and I've not had a problem until this weekend. Any suggestions?
