Tube Shock Towers!
Dan Fredrickson
Here is a pair of 1.5"x.120 wall DOM shock hoops. These are not the typical both sides even type everyone else makes because often your mounting surface and where you need to mount them simply have to be different. These make it easy to mount them tilted forward or rearward and have enough tube. If you are one of the lucky few that can mount them straight up and down just cut off the extra tube!
They come with two pair of our curved shock tabs so you can fine tune the height adjustment by the position of the tabs.
Shock Hoop 1.5" - RuffStuff Specialties
