Transmision long shift 2-3
Flyby
My 98 TJ 32rh auto trans was long shifting from 2nd to drive. I changed the trans fluid and filter. Ran 12 qts thru it to flush it. Helped about 85% today I talked to a transmission shop and they told me that there is a Service Bulletin on this problem. He said the seals get hard when cold and need to be softened up. He recommended TransX an additive for 30 days or until it stops slipping slow then flush the trans again. Anyone else ever heard of this?
Passing gear linkage may be missing the return spring. If it's pushed down and stays down, it takes longer to upshift.
