prariepunk Active member Aug 25, 2013 #1 I found a '99 TJ Sport that had been rolled. The owner bought a new tub but it just sat. tub & drive train $750. It's a 5spd. Could I swap in the 5spd & t case into my jeep?
steady.foot New member Aug 26, 2013 #3 As long as the rolled jeep has the same engine as yours, It should have everything you need.
B BaconYJ New member Aug 26, 2013 #6 It should bolt up. You will need the entire clutch assembly (pedal, Master, ect). Bacon
prariepunk Active member Aug 26, 2013 #7 The guy said it's got everything as far as the drivetrain goes
steady.foot New member Aug 27, 2013 #8 You might need a new computer for your year with a standard transmision.
prariepunk Active member Aug 27, 2013 #9 Chances that the '99 computer would work in my '05 TJ... Probably not good, right?
steady.foot New member Aug 28, 2013 #10 I don't know, But i do know there diferent from an automatic and standard.
B BaconYJ New member Aug 28, 2013 #11 Any chance you can pull the manual computer too? Not sure if they would be a simple swap such as, plug and play. Bacon
Catoctin Jeep Official Vendor Aug 29, 2013 #12 Dont forget you will need the crank bushing for the input shaft.
