1063156
until i get my giant k and n filter ive opted to tweak my xjs intake . Heres a few things to do in under an hour or two, with out having to buy anything.
Notice where your air box gets its air from. On all the xjs ive seen theres either a pipe with an opening almost behind the headlamp or a pipe that points down towards the ground to the side of the headlamp.
Mine is the latter.
All you have to do to gain more power and increase your acceleration a heck of alot is toy with these things. I cut the little tube that points down so that any air rishing at my grill goes ito the pipe and wow what a difference. more power, and a crapload more acceleration.
I used to redline at around 25-30 in my 1st gear on my 2.5 with the AX4, now its still crusin in 1st on 35. Big increase of power.
2. Notice the pipe that connects your airbox to your intake, it you look on the inside its really bumpy. Take it off and throw it away. Now get either a piece of rubber tubing or plastic, just anything in your garage that will fit and thats smooth on the inside and put that on their instead. Bam more airflow.
3. For all you guys with the k and n or other air tube set up heres a way to gain some more power, go look at your grill on the drivers side and look for the hole behind you grill to the side of the air box. use pliers or tinsnips or something and rip that hole open to make it as big as possible, now that k and n will have more air to filter.
try these things and i know they work cause ive done thenm myself. free performance whats better than that.[addsig]
Mine is the latter.
