Hi,
I have a new 2007 Grand Cherokee and upon acceleration it makes a ticking noise that sounds exactly like a valve lifter. Dealer says it's normal and is probably the catalytic converter material. It driving me nuts and would like to eliminate it.
This ticking is most noticeable with a mild-warm engine AND under light acceleration above 1000rpm. At idle it is hardly noticeable and revving up the engine in neutral without load does not produce this ticking sound. COASTING THERE IS NO TICKING sound, but at the slightest acceleration the ticking is there. To be clear this ticking is more related to a combination of engine load and rpm and is absolutely not related to speed. It is not loud but loud enough to hear it with the windows down and driving with or without lowfan-A/C.
It is very difficult to pinpoint where it is coming form. It is definitely not coming from any accessory belt driven devices. So far I could only find that it is SURE coming from the driver side as during idle it is noticeable in the driver side wheel well and is a little noticeable in the passenger side wheel well.
