think i've got it!!!
Burger
Ok still have a little snow here......got in a flat place that was slick and stopped......backed up and back tires spun.......put it in 4hi backed right up.......i bumped the shifter with my hand tried it, and it spun......took it out engaged it again worked fine.......bumped it it was out! Got to adjust the shifter linkage a little wouldnt you say?
Well I adjusted the linkage and it works! Whenever I pull forward it is in and stays in.......then I back up and it goes out or vice versa? What could be causing this? Any ideas?
