mingez
the saga contimues...
There's a new 4x4 coming to the US: the Crosslander.
It has a landrover feel, and looks pretty neat. I guess it was a Chech military vehicle. I think I like it, and the price is right.
Specifications
- Engine:
- Type: 4.0 liter V-6
- Aspiration: EFI
- No. of Cylinders: 6
- Bore & Stoke (mm): 3.95 x 3.32
- Compression Ratio: 9.7:1
- Maximum Horsepower: 207
- Max Torque: 238
- R.P.M @ Max Torque: 3000
Transmission:
- Wheel Drive: Permanent 4x2; Part Time 4x4
- Type: 5-speed; Manual and/or Automatic
- No. of Gears: 5 + 1 synchronized
- Ratio of Gears: 3.40; 2.05; 1.31; 1.00; 0.79; Reverse 3.40
Suspension:
- Front Axle: Coil Springs & Shock Absorbers
- Rear Axle: Leaf Springs & Shock Absorbers
- Differential: Symmetrical
- Ratio: 3.73
- Brakes: Hydraulic Dual Circuit, Power Assisted
- Front Axle: Ventilated Disc
- Rear Axle: Drum
- Power Steering: Hydraulic Power Assisted
- Turning Radius: 41 Feet
- Max. Slope (degrees): 40
Dimensions:
- Length: 178 in.
- Width: 72.2 in.
- Height: 73 in.
- Wheel Base: 102 in.
- Ground Clearance: 7.8 in.
Fuel Consumption
- City: 17 MPG
- Highway: 22 MPG
- Fuel Capacity: 25 Gallons
Trailer Towing Capacity:
- With Trailer Brakes: 5,049
- Without Trailer Brakes: 1,650
The Cross Lander 244X, which is based on a military line of vehicles that have been produced for more than 50 years in Eastern Europe, is set to make its U.S. debut in about six months. The vehicle is expected to sell starting in the low $20,000.
Specifications
- Engine:
- Aspiration: EFI
- Max Torque: 238
Transmission:
Suspension:
- Ratio: 3.73
- Rear Axle: Drum
Dimensions:
- Length: 178 in.
- Width: 72.2 in.
- Height: 73 in.
Fuel Consumption
- City: 17 MPG
- Highway: 22 MPG
