tackling the failoed smog test Part 1.
8177
If you have been following along with the struggles to get the wifes jeep smogged I'll let you know that everyone has been a great help. So lets get this party started. Going out to a compression test in a bit but before I even waste any more time and money I need an answer concerning the Cam and timing. The CARB requires that the 258 be timed to 6 deg BTDC. I have an after market cam in it Crower 44243. The Cam card is speaking Swahili and I don't even know if I can run it at the right timing. Intake duration 256 lift .437. Exhaust duration 264 lift .445 Intake opens -11.0ATDC closes 25.0ABDC exhaust 38.0BBDC closes -14.0BTDC lobe separation 112 duration in 194 exh 204 lobe lift intake .273 exhaust .278 at .50 lobe lift.
If I cant get the timing to 6 deg all is lost.
Jim
