Hi guys ...
I wish i knew all the specs on the nv 3550 or nsg 370....detailed specs..
like crank angle sensor position, flywheel differences...etc etc
If you have detailed mesurement,s i,d like to know them.
I,m not sure if removing the nsg(nfg) trans for a nv3550 is possible...
Any info would be appreciated.
I know the crank angle sensor will be a pain,
FOR Instance...the crank sensor, can i rotated the flywheel one or two bolts to realign with the crank angle sensor on the nv 3550 from the nsg 370...theres no front harmonic relocater that i know of for the crank signal, depending on the flywheel mesurements obviously.
Again ..any info or suggestion...maybe a different trans...
thanks
thanks
