swap
85xj
clutch slave cylinder push-rod problem
i have a 1985 xj,will the ax15 5spd transmission and np 231 transfer bolt in
no... diff bellhousing i *think* but im pretty sure it wont bolt up
im talking about mount wise will they bolt up, i plan on putting a 5.0l ford in it and i don't what to use the weak t5 transmission
thanks
The AX15 won't bolt to the 5.0L, get a transmission that will bolt right up so you don't have to spend too much $$ on adapters.
Either way you'll have to modify the transfer case crossmember to the transmission/transfer case you choose.
Getting Air
ok if i had the cross members from the xj i got the ax15 and transfer case from, using the ax15 transmission and cross member that came with it , will it bolt to my 1985 xj,
thank you
