1058170
I use to be a Remote Starter Installer, and had a number of problems with XJ hoods, If i remember correctly(and I'm thinking back a couple of years) there are two bear claw type latches on either side and what happens, is the cable streches out and either one or both latches won't release. I found that if you disconnect the cable from the handle inside vehicle and use a pair of visegrips to pull on the cable, you will release the latch. Unfortunatly this is only a temporary fix.[addsig]
