stuck brake bleed nipple
hoobness
Hey all,
Bleeding the breaks yesterday and i get to the front passenger side and the nipple is stuck shut. I ended up rounding it, then making it worse with vise grips! I need it out, my pedal now goes to the floor, and I cant drive my newly lifted jeep very far!!
I dont care how I get it out, I figure Ill have to replace the nipple anyway. OR is there a way of getting the air out of the lines bleeding only 3 wheels? So far it hasnt worked!
Any advice?
small twist socket maybe? if you didnt' get it off with REAL vice grips.. its probably looking to break... you might be replacing your caliper soon...
Craftsman and some other manufacturers make a socket that removes stripped bolts, has sharp cutting edges inside the socket.
Don't waste your time trying to get the bleeder out. Get a new caliper from the parts store for the 10-30bucks you spend will save you time and headache of trying to get that bleeder screw out.
Also a tip for next time as you are trying to loosen the bleeder screw with your wrench lightly tap on the head of the screw with a hammer this usually works unless the screw was already messed up also if you werent next time try using a flare nut wrench
Evan
