when i turn the key my xj wont start unless the clutch is in this one exact spot, if its not it will crank once twice if im lucky grind the starter or noting at all will happen. could this be caused by the neutral saftey switch? i had this problem before and it went away. when it went away i didnt even have to push in the clutch to start it, so what is worn here. is there a way to bypass the switch and where is the switch even at! thanks guys
