Starter removal 1989 Cherokee 4 cyl
pancho
RE: Welding
I am attemping to replace the starter on my 1989 jeep cherokee, 4 cylinder. It appears the starter is held in place by two torx bolts. Does anyone know what size bolts these are and any suggestions on removing them and the starter.
Thanks
RE: need help from yj guys
?? should need a 9/16 socket to get it off?
Hi,
When my Cherokee had a starter motor, it was mounted with two standard bolts to the transmission bell housing.... Are you sure they are Torx bolts?
-Nick :!:
