Hi
I have a 98 Cherokee(XJ). I recently fitted some load hog helper springs. This increased the lift on the rear to a large degree. If you look at the vehicle side on you can see the roof line sloping from back to front, as the rear is obviously allot higher.
The result was more stability but huge wining and droning noises throughout the cab.
What can be done to remedy the situation and why do these noises happen?
Mike (SA) :?
Mike (SA) :?
