Spray Paint on Top
kmcd20
Hello,
Sorry to have this be the topic of my first post...I did some research and found out that Jeep tops are made from SMC (sheet molding compound). Does anyone know how to get spray paint off the inside (white surface) of a Jeep top? Not sure what to use that won’t break down the SMC. It’s a small spot, maybe 6” x 3”. Thanks for any insight.
Never had to deal with that.
If fresh. Less than a few hours you might be able to scrub it off with a plastic brush and soap and water.
More aggressive is wet cloth and baking soda.
Buff it off if smooth area.
Maybe goo gone but start in small area.
Is it latex paint or a solvent based?
Denatured alcohol or products like 'goof off' or 'oops' will dissolve dried latex paint. I don't think it would harm the top but I don't know for sure. ,,Solvent based paints require a hotter thinner which would likely harm the top.
