speedometer calibrator
phatyaspen
i need a speedomoter re-calibrator... i need it asap where is the best place 2 find one i am looking and searching franticlly. i just got pulled over for speeding and its sux help me please!!!!
First some info is needed, since your speedometer is off (we are guessing here) that you have lifted your jeep and put bigger tires on and/or re-geared it. Now I know for a fact on a TJ it is not a cable but an electronic sensor and you have to change a small plastic gear near the out-put shaft for the right tire size and gearing. An easyer way is to look up Automotive repair shops in your area and find a speedometer shop that can re-calibrate it for you. With the reciept in hand you might have a good chance that the judge will dismiss the charges and or reduce the fine since the reciept will say yours was off.
Good luck...if nothing else the weekend drivers ed class to wipe the ticket off is not that boring...NOT!
Here's a link that can help you figure out how fast you are going until you get it squared away:
http://www.4lo.com/4LoCalc.htm
FYI: For the purpose of using these tables, the stock jeep tires (215-75-15) translate to 27.696850393700785 inches.
Also check out this previous post:
http://www.jeepz.com/index.php?name=PNphpBB2&file=viewtopic&t=318522&highlight=
I think 4wd hardware sells a module that adjusts your speedometer for the bigger meats. somewhere between $100&$200 It should be in their catalog, check quadratec, too!
4wd hardware: part#50110. $169.95 Jet Accu-Speed.
you might find it cheaper if you run a search on the web
good luck, bummer about the ticket!
We are going to moab
Hello phatyaspen,
I had a similar speedo problem when I acquired the "Bubbacon." The Jeep had bigger than stock tires, but at the time I had no idea what the stock tire size might have been. So, I went with a method similar to jackal's, as explained in a previous thread.
I knew the t-5 transmission ratios, the differential ratio, and I measured the actual rolling diameter (not the calculated diameter) of the rear tires. With that information in hand, I dumped the information and a formula into an Excel spreadsheet for calculation.
I then printed and laminated the table and taped it to the driver's sunvisor. Here is a picture of a portion of the spreadsheet:
The table entering arguments are desired MPH and transmission gear. The intersection is the engine RPM. By referring to the chart, I could drive by the tachometer instead of the inaccurate speedo. (Watching the road is for sissies!) Actually, after using the table for a while, I learned by repetition the RPM needed in the various gears for the few commonly encountered speed limits.
A lot of work to avoid buying and installing a new speedo pinion gear? To be sure, but at the time I had bigger and higher priority Jeep-related issues with which to cope.
Of course, after having done all that, I then knew by how many miles-per-hour the speedo was off and could compensate for the speedo reading. But, hey! Computational excess is good!
:mrgreen:
The "Bubbacon" cockpit modded out w/column-mounted TJ or GC tach, RPM-to-MPH visor chart, S-10 map-lighted interior rear view mirror mounted below a Honda-Civic (ricer implant alert!) digital clock.
The table method might yet be useful, however, for those with broken speedos or who frequently swap between differently sized highway and off-road tires.
Tounge-in-cheekly submitted,
:wink:
Gadget
for that price... buy a handheld GPS.. it will tell you your real speed and keep you from getting lost too!
Fixing the speedo. That takes all the sport out of it. Mine are off in both my 4x4. I just matched the speed to my wife's car and figured at 65 I was about 5 off. I just drive 5 mph less that should cover any speed since my jeep will not go faster.
well, check out the chart in the link I posted, and get the part # and go to town....it's not a hard project, and the directions are right there for you to follow.
Rob 8) :P :)
