Speedo & Odometer Not working at all!
The speedometer is electronic and receives a signal from the speed sensor on the transfer case rear output. Check the signal to and from the sensor, and the wiring.
Where is the tranfer case ) picture? Where is the wiring at? Engine compartment?
Also would the odometer stop also, Sounds like the P.O Broke it to stop the ODometer?
The PO may have simply unplugged it.
Find the rear driveshaft, it's the tube that transfers power to the rear axle. At the forward end of the driveshaft is the rear output of the transfer case. Look for a plastic part on the driver's side of the rear output, that is the speed sensor that sends the electronic signal to the front. You should see the electrical connection and wiring coming from it.
Ok,
I found two unplugged wires in the car. One under the dash board and cannot see where to plug this to. It has about 5 prongs on it.
Also there is a simaler looking plug on the transmission just dangling there, I do see another plug next to it plugged up ( there is threds for somthing to screw on i beleive then to be plugged up.. Is this to do with the Odemeter & Speedo? I am getting not thing to my speedo , Tripometer, Odometer.
Ok,
I think your speedo cable has a metal type threaded case around the wire harness, you slide it onto the wire prongs and thread it on.
