1051433
Hi There,
I am upgrading my Heep and must sell the following.. Parts and I reside in Toronto, Ontario, Canada..
The following is in my Heep right now. This would be a direct Bolt in with all driveline angles etc tested.. Castor is proper. yada yada yada.
Front Axle: Ford Bronco Dana 44: ( Driver Side Dump)
* 30 Spline shafts
* Chevy Flat Top Steering Knuckles
* All custom steering, Hyme jointed
* 4:10's,
* Extra carrier (Lincoln Locked)
* Super Winch Hubs
* Set up for a Spring Over Axle
* 5 on 5.5 Bolt pattern (CJ)
Rear Axle: Scout Dana 44:
* Disc Brakes
* 4:10's
* Detriot Soft Locker
* Trac Arm
* Set up for Spring Over Axle
1994 NP 231 T-case w/ SYE (Slip Yoke Eliminator)
This direct bolt in will net about 5-6 inches of suspension lift w/ proper driveline angles, castor etc. All steering is included, High steer. Buyer will need to install an add a leaf into their original/stock YJ leaf pack. I am currently running this set up with a 2 inch body lift and clears 35 inch Boggers with no probs.
I am asking $3700.00 Canadian obo.
e-mail if interested. bush_pig1978@hotmail.com
Thanks 4 Your Time
Bp.
			Hi There,
* 30 Spline shafts
* 4:10's,
* Super Winch Hubs
* Disc Brakes
* 4:10's
* Trac Arm
Thanks 4 Your Time
Bp.
