JEEP96grandCHEROKEE
so..if i add a 3" suspension lift to a 2" bb lift then i would get a total 5" of lift...right?
yep, with 5" on a zj, you'll almost definately want new control arms. t-case will probably need to be dropped. and brake line extensions wouldn't be a bad idea.Snitty said:you'll probably want to upgrade your control arms with that sort of lift.. but you're right on the numbers
yeah i'm hoping thats what southern meant. but whatever, i agree with you wrangles. DEF new shocks. i have only a 2" bb, and i def use new shocks.88Wrangles said:I could NOT imagine using stock shocks with a 5" lift. They will blow
those are the shocks that come with the RE 2" bb. so those are in turn the shocks that i currently have on my whip, i like em, for the money, not bad shocks at all, i'd recommend them if you're going to the more frugal route.Bounty__Hunter said:Yes, new shocks with that much of a change in height.
Check out Doetsch-Tech 3000's if you want a smooth ride, you can get them for about $30 each from www.rubiconexpress.com .
